FS: Sony MDS-JA333ES *SOLD*
skierMD
Hello MD fans,
Just purchased a NH1 and I am selling my favorite piece of hi-fi equipment, the black Sony MDS-JA333ES (USA model). I am getting rid of all my MDLP equipment to move room for the new Hi-MD home units when they become available. I am the original owner, have used it for only a couple years, and still have the original box. I used the unit to record vinyl dj mixes onto MD, and then dubbing it onto CD, etc. It has everything you would want from digital to analog volume increasing while recording. The only signs of wear are a few scuff marks and scratches on top rear of the unit. Will ship anywhere in the USA.
Everything in the pictures is included:
The main unit, the remote control, original box.
I have misplaced the manual, but it can be found here:
http://www.minidisc.org/manuals/sony/sony_...33es_manual.pdf
MDS-JA333ES - msrp $1000.00 asking $500.00
• ATRAC Type R Compression Method
• Dynamic Range >106 dB
• Signal To Noise Ratio >106 dB
• Harmonic Distortion <0.0025%
• A/D Converter 24 BIT
• MDLP (MiniDisc Long Play Mode) Yes
• Shock Resistant Memory Yes
• CD Text Transfer Yes
• Optical Inputs 2
• Coaxial Input 1
• Line Level Output 1
• Optical Output 1
• Coaxial Output 1
• Headphone Jack 1/4" Type
Weight: 23 lbs. 2 oz (10.5 kg)
Dimensions: 17 x 4 7/8 x 14 3/4" (430 x 123.5 x 375.5 mm)
All information was obtained from the link below:
http://www.sel.sony.com/SEL/consumer/ss5/h...gitalrecorders/
user posted image
user posted image
user posted image
The flash makes it look way more scratched than it is, you can only really see the ones in the back:
user posted image
